Unable to connect to the mysql localhost server using flexsim connector.
ajay13101997
Message 1 of 16
ajay13101997
[ FlexSim 22.0.2 ]
please find the flexsim snap, mysql server details snap, mysql db snap.
I am not able to connect to mysql db from flexsim, i am running mysql application and flexsim application on same system.
need support to create connection between mysql db and flexsim.
Thanks in advance.
Replies (15)
Message 2 of 16
Ben_WilsonADSK
Have you tried removing the ",3306" from the database address, so that the only text is localhost?
Message 3 of 16
ajay13101997
Yes i have tried putting only localhost, but still it does not work
Message 4 of 16
jason_lightfoot_adsk
Can you connect with another application like Excel or MSAccess to import data? Is there a confluct on port 3306?
Message 5 of 16
shanice_c
Have you tried type sakila.db in databasename field? I made this mistake a few days ago.
Message 6 of 16
ajay13101997
I have tried connecting via MS SQL it has connected successfully, but with mysql it is not working
Message 7 of 16
So you can't connect excel or MSAccess to mysql either - that suggests it's a MySQL/machine configuration problem. In testing a similar install to yours with the same port numbers FlexSim connects fine just using "localhost". Have you checked the credentials? You could also try shanice.c's suggestion.
Message 8 of 16
ajay13101997
Ok sure jason i will try your and shanice suggestions
Message 9 of 16
SebastianCanasV
@TheHero
I also had this issue while trying to connect to MySQL. I am not totally sure why this happens but I fixed it removing the lastest version I installed of MySQL Server (8.0.29) and then installing an older version (in my case I installed 8.0.1)
After that I could connect to the database succesfully
Message 10 of 16
kavika_faleumu
Hi @TheHero, was one of Sebastián Cañas's or shanice.c's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Message 11 of 16
ajay13101997
i tried it out but having same error
Message 12 of 16
ajay13101997
i am using workbench 8.0.28
Message 13 of 16
shanice_c
Would you try not type port number 3306?
This is my connection.
Message 14 of 16
SebastianCanasV
I also had problems with that version. Try using an older one!
Message 15 of 16
ajay13101997
thanks, let me try with 8.0.1 version
Message 16 of 16
borja_lorenzo4278
Hello @TheHero ,
I have experienced the same error with version 22 of FlexSim. I was able to solve it with version 24.1.1 of FlexSim and version 8.0.26 of MySQL.
Have you been able to solve it?
Which version of FlexSim is giving you this problem?
