Unable Read/Write Modbus Registers from Node-Red
flavia_p2
Message 1 of 13
flavia_p2
[ FlexSim 19.0.9 ]
Hello everyone,
I have been able to read registers of the simulation environment using modbus in nod-red
33374-1602605291815.pngNow I was trying to write to the registers but it has been impossible. I used in the same modbus in node red sending the a value 1 to flexsim register 7 and the conveyor belt but it didn't move.
I have seen in other publication with this example working, I don't kown if youi have any suggestions for me?
Replies (12)
Message 2 of 13
Ben_WilsonADSK
@Matt Long, @Joshua S, can you please respond to this emulation question?
Message 3 of 13
joshua_s
@Flavia P2
First make sure you have the connection you want to use selected in the picture below. You have it correctly selected for your Sensors.
If that doesn't work I'd like to see if it's reading anything in general. Add a code snipet to the Action Field and enter this print(newValue,oldValue);
Then open up the Output console and see if anything is being written when you run it. Do this for all the registers you want to listen to.
Message 4 of 13
flavia_p2
Thank you I will try this and let you known
Message 5 of 13
flavia_p2
So after I tried your solution with Code Snippet this was the result on the Output Console
I'm new to FlexSim, so I don't know how to intrepert these results, if could help me again please it would be great
Message 6 of 13
flavia_p2
for another register the results were totally differente
Message 7 of 13
flavia_p2
Just to let you know that I was already able to control de conveyor belts using the Node-red application
Message 8 of 13
isabella_ac
@Flavia P2 Could you share how did you control de conveyor belts using Node-red, please?
Message 9 of 13
leelichou1112
@弗拉維亞P2 I want to know how you use node red, because I am currently using this method
Message 10 of 13
ryan_c10
Hi @立洲,
Could you please post this as a new question? You can link to this post in your new question if that would be helpful for others trying to answer your question. Thanks!
Message 11 of 13
ryan_c10
Hi @Isabella AC,
If you haven't solved this problem already, could you please post this as a new question? You can link to this post in your new question if that would be helpful for others trying to answer your question. Thanks!
Message 12 of 13
leelichou1112
@約書亞S 我想知道你對node red和Flexsim之間的聯繫的想法和秘訣
Message 13 of 13
joerg_vogel_HsH
@立洲 , please create a new thread by using action field at this answer site thread ask a question from above. This site has got a different policy than bulletin board forums: You ask a question and therefore you create a new thread, you get answers, you can accept an answer to your question, than this thread is finished. You can write comments to clarify answers or questions.
There is an article which describes how to use this type of forum: Best Practices for using this Answers site
