U-shaped layout connections not working
Samsimulation
Samsimulation
[ FlexSim 24.0.0 ]
Greetings everyone,
Firstly thank you for being an amazing support system!
I've perplexed how to use connections for operator to transport and get the flow going for U-shaped layout
I've attached my Model for reference.
U shape model practice.fsm
Please if anyone can show in form of model, how to assign connections, it'd be really helpful.
Thank you all for being a great support system.
moehlmann_fe
When you activate the "Use Tranport" option, the field below needs to be a valid reference to a task executer object in the model that should be used for the transport task.
The syntax "current.centerObjects" accesses the object that is connected with the Nth centerport connection to the object to which the option field belongs.
