Two operators working in parallel and independent on the same item type
larissa_m3
larissa_m3
[ FlexSim 19.1.0 ]
Imagine a manual station of window gluing in a automotive assembly line. Cycle time of 14 minutes. Two operators, each one has his separate tasks, like pre assemblies and rear/ front window preparation. When they have to fit the window on the body, they need both working together.
I tried multiprocessor, but it has the process one followed by the next. I have to make both operators work independently in the same itemtype and at two points work together also in the same itemtype.
The assembly line is stop and go.
sebastian_hemmannE3JAU
Sounds as if you should build the processes (times) in Process Flow and Synchronize the parts the operators have to do together. Using a list would be the best way I think.
If you want further information or any help, please share a(n) (example-) model with us!
larissa_m3
This is a very simple model of what I want to do. modelo3-flexsim.fsm
In the processor, I added some of the activities. But the pre assemblies, both operator can do at the same time, it does not have to follow a sequence.
The model does not even work like that.
So I´ve attached a model that hopefully meets your needs.
You can add further Processes or Sync Processes. Hope you can Figure out, what I did!?
19299-modelo3-flexsim-sh.fsm
zac_higleyQBKLZ
@Larissa M3
When looking at your model the you should just be referencing the dispatcher to handle which operator will work on a task. I have changed that in the model I have attached. (Just for visual I had the item change color after each task.) As for working on an item at the same time Sebastian's answer works very well. In his case you could also use a Synchronize Activity instead of the "Sync List." (There is a tutorial that you can view to help build a model with the Sync Activity.)
modelo3-flexsim.fsm
