Trying to create the correct process flow
lilian_fonseca
lilian_fonseca
[ FlexSim 16.1.0 ]
bod-line-final-visual-presentation.fsm This is what I am trying to accomplish in the attached model: the process starts with the robot loading the first "door"; then it waits for the "carton" to be created and as soon as the carton is in the Combiner 1, the robot unloads the door on it. At the same time, a pallet is generated in the end of the line and then the robot picks it up and place it on the combiner 27. After that, the robot picks up the packed door and place it in the pallet. Then a second door is created, the robot repeats the same process of load and unload so that now the same pallet has two doors and it goes to the end of the production line (queue 30). That would be the end of the process.
Well, I am already facing the following error message as soon as the simulation starts to run:
If anyone could help me to obtain the process I have just described, I would really appreciate it.
Matthew_Gillespie
In your Create Object activity you need to assign the pallet you just created to the "pallet" label and not the "item" label since you're trying to reference it later using the "pallet" label.
Matthew Gillespie
FlexSim Software Developer
lilian_fonseca
Yes, that is right. I'm still working with the process flow, so I will post another question about it soon, because it is not working the way I want yet. Thanks!
