Trouble with global table import in picking model
tomonori_s
tomonori_s
[ FlexSim 18.0.10 ]
We began with a simple picking model (sample-ver04.fsm) and imported "import.xlsx" into a global table to be used in the model. The result is "sample-ver04-import.fsm."
If you run a simulation, the operator will now move far away instead of normal movement. Please assist.
joshua_s
Use the command executeCell when you want to convert a reference string to a pointer value. The picture below shows the change that is needed, after that the model runs fine.
tomonori_s
It worked with the posted function.
Thank you very much.
