Trigger "On exit" Problem
samueltan5550
samueltan5550
Morning, I have a problem with the trigger 'On Exit', I want to close the output after 13 boxes were transported, but it close the output when 13 boxes is input. Thanks a lot
kavika_faleumu
Hey @samueltan5550, you can use Process Flow to add a Custom Code activity that closes and opens object ports.
You can add logic to open/close any input/output. You can either put a condition to close the port when certain criteria are met. You could also use a Batch activity to batch however many tokens you need until the criteria is met.
Hope this helps.
