trigger on run stop problem
dongdong
dongdong
[ FlexSim 24.2.2 ]
Hi, currently my model is paused, and I'm using the trigger on "Run Stop" to open a socket and receive messages. When a specific value is received, it should stop receiving and continue running with `go`, but it doesn't proceed as expected. How can I resolve this?
joerg_vogel_HsH
@dong, There does not exist an command interpreter, that runs during the program flexsim is open to iniate automatically a modell run. Once a model has been called a stop on it, the model will only start by a hitting the run button.
If you want to have such a functionality, you must use an external procedure on windows system level, that emulates activating a button in a FlexSim program window.
dongdong
However, I would like to achieve this through socket listening, but I'm unable to set up the listening correctly. What should I do?
joerg_vogel_HsH
@dong, this additional condition does not change anything in my answer. As long as you stop your model run at a timestamp, you will not get it to work again still from any code from within your model.
logan_gold
Hi @dong, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
