Travel to Object with Travel Destination Force of SocialForeceSystem
wooram_kim
wooram_kim
[ FlexSim 24.1.0 ]
I want to move a Task Executer by Activity with SocialForceSystem navigator that has a force of Travel Destination. But when the Task Executer arrives at the object, the system shows an error (time: 14.100000 exception: Exception caught in Executive::processeventinlist().) and the navigation system does not work any more. I attached a file, please run the model. When the task executer arrives in a queue, the exception occurs. (travelforce-2410.fsm)
I found that the error does not occur when I use A-star force or Activity / [Load].
Thank you.
philboboADSK
This is a bug. When the agent reaches the goal, it finishes its travel task, but doesn't complete the goal. So then the next update cycle, the travel task is NULL and throws an exception.
I'll add a case to the development list to fix this. Thanks.
Your workaround of using Travel to Loc to travel to the object's location rather than to the object itself is a good solution in the meantime.
travelforce-2410_3.fsm
Phil BoBo
Sr. Manager, Software Development
Matthew_Gillespie
@WooRam_KIM
This issue is fixed in the latest bug fix releases: 24.0.5 and 24.2.1.
Matthew Gillespie
FlexSim Software Developer
