Travel to location error
giacomo_lupi2
giacomo_lupi2
The Travel to Location positioned in the General Process Flow in the following image is not working.
The TE should move to the XY coordinates that I assign via labels, but instead it only makes a small movement and then proceeds to the next activity. Until recently, it worked without any issue, then suddenly it started behaving this way, and it doesn’t seem to me that I made any impactful changes.
Additionally, every time I perform a reset of the model, some messages appear in the console whose meaning I do not understand.
Could you help me? Also, if you have suggestions on how to improve the Process Flow, I would be happy to hear them. Thank you.
FelixMoehlmann
It seems that the "Shuttle 2 Process" Flow has become corrupted in some way. Deleting it fixed the issue. Why are there even multiple identical Object Process Flows? You can just link all shuttles to the same and remove the others. Having a shuttle assigned to two copies of the Flow might have been what broke the model.
