Travel time operator: simulation model results not equal to hand calculation
frans_dg
Message 1 of 9
frans_dg
[ FlexSim 20.1.2 ]
Dear reader,
The issue: the travel time of my operator in the simulation model is not the same as my hand calculations. The operator has a speed of 1.11 m/s, acceleration of 0.44 m/s, and deceleration of 1 m/s. The model is set to meters and seconds.
I created a situation in which an operator has to travel from node A to node B. The distance traveled is 11.6 meters according to the operator's statistics. I used a Staytime activity in the dashboard to measure the time the operator travels. This was equal to 11.71 seconds.
However, if I calculate the travel time by hand, I get a travel time of 12.27 seconds. I used the following equation:
distance = 0.5*acceleration*(t1)^2 + speed*t2 + 0.5*deceleration*(t3)^2
I assumed a constant acceleration, therefore, t1 = 1.11 / 0.44 and t3 = 1.11 / 1. As for t2, this has been determined by dividing the remaining distance (distance when there was no acceleration) by 1.11 (the speed).
Since I assumed that the acceleration and deceleration are constant, the outcome of my hand calculations should be the shortest time possible, which is 12.27 seconds.
I could understand if the operator in the simulation model would take a little longer, for instance, if the acceleration and/or speed would not be constant. However, as I see it, the travel time in the simulation model can never be shorter than the hand calculation.
Can somebody please explain why this happens?
With kind regards,
Frans
Replies (8)
Message 2 of 9
allister_wilson
Presumably there's a problem with your test setup or the way you're measuring time, in the attached model an operator with the same acceleration / deceleration / speed as yours takes 12.27s to travel 11.6m as expected.
20201030_operator_travel_time.fsm
Message 3 of 9
frans_dg
This is odd. Indeed, in your model, it is working fine. In case I find the problem, I will add it to this post. It most likely has to do with the AutoCad drawing that I added to the model. Perhaps something went wrong with the scaling.
Message 4 of 9
Ben_WilsonADSK
Hi @Frans DG, was Allister Wilson's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Message 5 of 9
anjunittur123
hey @Allister Wilson can you please share the same model in 20.0.0 version? It would be a great help!!
Message 6 of 9
allister_wilson
Is there a reason you can't install a more recent version of FlexSim?
Nothing in that model requires a license to access, if that's what you were worried about.
Message 7 of 9
anjunittur123
I am using Flexsim 20.0 version. I am not able to open the model. So I asked for the 20.0 version for your model so as to refer.
Message 8 of 9
allister_wilson
Yes, I've seen you post the same request on another answer.
You can download the latest version of FlexSim from https://account.flexsim.com/downloads/.
Multiple versions of FlexSim can coexist on the same computer, you can have 20.0 (with a license) and 22.0 (in Express mode) both installed.
Message 9 of 9
anjunittur123
That's great, thank you
