Transport to different locations depending on amount.
kamil_ks
kamil_ks
I created some transportation logic but i am struggling with some conditions of it.
Pallets form Bufor need to go to Queue1 or Queue2 or Queue3 in equal of total amount. So after all Queue1 has 33,33% of pallets from Bufor, Queue2 33,33% of pallets and Queue3 also. It needs to go Randomly, not in the sequence like first 33% to Queue1 and so on.
How to crate a token ,,Destination" that tells Transporter which Queue it needs to choose by the total amount ?
transportationcondition.fsm
kari_payton
@Kamil KS you can use a decide in the process flow to direct the logic. The decide is set to a percentage, sot he drop-off locations are randomly assigned.
Create a label for the queue called "Destination" that references the options for dropping off the pallets.
Also make15802-transportationcondition.fsm sure all of your token labels have are the same in spelling and caps. for example you talled token.destination and token.Destination (the capital D matters).
kamil_ks
Thank you very much, that is the perfect solution of my problem :). On the other hand do you know how to create a logic when a transporters capacity equals 2 and he can only pull 2 pallets from a ,,Bufor". Am i supposed to use Wait for Event or can i change properties in Event-triggered Source ?
kari_payton
@Kamil KS in this situation I would use a list if you are familiar with that concept...? If not it would probably be easier to use the logic in 3D. Post your question as a new question to get more views.
kamil_ks
I am not sure how to fill gaps in the Pull from List. Is it request number ?
twopalletslogic.fsm
