Transport by operators without job sharing
marszalek_k
marszalek_k
Community Visitor
Community Visitor
I would like to ask You how to resolve the situation in simulation where two operators takes the parts from one queue without sharing the process between two combiners.
So, each operator should work with his assigned combiner
Operator1 - Combiner1
Operator2 - Combiner2
What I did, I added Dispatcher1 do my simulation. Operators are assigned to Dispacher1 and Dispacher1 to Queue1.
And it works however operators are helping each other delivering the parts to both combiners whenever needed.
file attached.
Thanks in advance for Your support,
BR, KM
FelixMoehlmann
You can use the "Centerport By Case" option in the Use Transport field of the queue. Connect both operators to the queue with a centerport connection. Then use "port" (the port number through which the item was send) as the case function in the aforementioned pickoption and set a different centerport rank depending on where the item is transported.
marszalek_k
Community Visitor
Community Visitor
Thank You moehlmann_fe for support.
Now it's working like I want it to 🙂
BR, KM
