Tracked variable minimun exception for 0
raul_vazquez
raul_vazquez
[ FlexSim 20.1.3 ]
Hi team,
Im creating a tracked variable in order to track content,max,avg and minimun individually per object and when i tried to get the minimum always is 0. there is a way that the tracked variable provide a the second lower value? could i get the second minimum value? is possible to do it without use the warmup time?
The code below is how I create the variable at reset for several objects using "usercommands" on reset.
treenode labelNode=current.labels.assert("ItemQty");
TrackedVariable.init(labelNode,STAT_TYPE_LEVEL,0);
thanks a lot
mischa_spelt
That 0 that you pass in as the third argument to TrackedVariable.init is the start value. If you initialize it to 0 and only set it to higher values afterwards, the minimum will be 0. If that's not what you want, you should make sure it starts at a higher value.
raul_vazquez
Thanks Mischa
