Tracked Variable line plot does not work with kinetic variables
sean_tully
sean_tully
I am modelling a water storage tank and am using a kinetic variable, storageVolume, to model tank volume (and net inflow). I don't set the volume directly, I'm only modifying storageVolume.rate in my scripts. If I put a Tracked Variable Table on the dashboard, I can see that the volume is correctly updated as the rate is changed, but if I put a Tracked Variable Line plot on the dashboard, it does not register any points.
As a quick hack, after I modify storageVolume.rate, I can do something like this:
storageVolume.value += 0.0001;
storageVolume.value -= 0.0001;
The above will make the plot work, whilst doing storageVolume.value = storageVolume.value will not.
This feels hacky - is there a better approach?
On a related topic, how can I generate a line plot of storageVolume.rate?
FelixMoehlmann
Install the chart components (Advanced tab in the chart properties). In the Statistics Collector that will now be accessible in the toolbox set the "Change Rule" to "Update".
To track the rate you can use a copy of the same Statistics Collector and just change the expression for the value column to use the rate property.
sean_tully
Thanks - that worked perfectly.
