Tracing Minimum Stock level of an SKU using Optquest.
sri_vikas_k
Message 1 of 8
sri_vikas_k
[ FlexSim 23.0.14 ]
Hi FlexSim Community,
I am using optquest for the first time to trace the minimum stock level of my SKU using optquest. Please guide me in the proper way to achieve my goal. The minimum stock velocity of my SKU is 10 per day.
Thanks inadvance.
MinimumStockLevel.fsm
Replies (7)
Message 2 of 8
joerg_vogel_HsH
OptQuest is a tool to test several simulation runs to find a setup of parameters to realize a desired goal.
If you want to record just a level of a variable or statistical value, you do this in your experimenter. @Sri_vikas K, what do want to achieve?
Message 3 of 8
sri_vikas_k
Hey @Joerg Vogel
I have data, that the stock velocity of the SKU is 10 units per day. I wanted to run the experimentor giving different values of stock velocities to check the minimum stock level of SKU(minimum content the SKU should have for production). How should I do it with experimentor.
Message 4 of 8
jason_lightfoot_adsk
Set up scenarios in an experiment job where you adjust the Parameter for each one to make it unique. You can create range-based jobs too if that suits your values better.
Message 5 of 8
sri_vikas_k
Hi @Sri_vikas K Thanks for the reply could you please add a bit more explanation, how to create a parameter on stock velocity ranging from 10 to 30 units. Thanks
Message 6 of 8
Message 7 of 8
joerg_vogel_HsH
Here is an example to create items by parameter value in Process Flow. A second really simple process keeps this model running at least for 3600 s. Otherwise it will end, when last item enters sink. ProcessFlow_create_item_velocity.fsm
It uses the experimenter and performance measure variable.
Message 8 of 8
Jeanette_Fullmer
Hi @Sri_vikas K, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
