To set 1 operator for output, the other for repair processor from breakdown
thomas890524
thomas890524
As title, how can I set 1 operator for output, the other for repair processor from breakdown?
-First operator works for just output.
-The other operator works for machine repairment.
Please kindly refer the attached file.
moehlmann_fe
The "Use Operator" and "Use Transport" options have separate fields that determine which operator to use. Just refer to the respective operator in each. Different centerport-connection ranks or direct references would be simple options.
thomas890524
@moehlmann_fe   Thanks for your reply. May kindly you check my model? I want to set 1 operator used to setup processor, the other operator to repair breakdown.
moehlmann_fe
Sorry, I don't know why I thought you asked for the transport option. Which TE is called for the repair is determined by the "Dispatcher" field in the down function of the MTTR/MTBF. In your model you just need to replace the 1 in the brackets with a 2, so the operator connected as the second center object is used for the repair.
