[ FlexSim 23.2.3 ]
Hey all,
Not sure if I am using timetables correctly or if I should do something different. I am trying to simulate a workforce that mostly runs 24/7 but manning goes up or down depending on the shift.
I have 2 types of Operators in two groups that simulates 2 different trades. During the first shift, all 10 Operators in each group are active. During second shift, manning goes down to 70% availability and the last shift goes down to 50%. I also have the Operators on a Parameter table to change the number of operators to see if adding more manning would impact the process. Even if I add more Operators, 70% of the manning would still be operational in the second shift and 50% would be available in the third shift.
In Shift2TimeTable and Shift3TimeTable, I tried to use the eyedropper or the add members to pick out the task operators I want to go down, but whenever I reset the model, either the task operators that I picked disappears or it just grabs the entire group causing them to all go down.
Not sure what I am missing. Thanks!
