Time Table pause process flow delay
jkquinsa
jkquinsa
I have a process flow that has delays in a task sequence. I am trying to make the tokens in the delay stop according to a time table to mimic work hours. However, the delay time continues even during off shift hours.
I tried adding code to the Down and Resume function within the time table and also using Preemption (Save / Release / Restore tokens).
However, I was not able to get it to work in the sample model.
I also tried using Token.stop() and it would put a red dot on the token but the delay still progressed (code blocks shown on the side of process flow for reference).
@FelixMoehlmann If you have time could you please help me with this?
Thanks!
References used:
Solved: How to Pause the delay token in process flow by using time table - Autodesk Community
Solved: Creating Shift Patterns in Process Flow - Autodesk Community
FelixMoehlmann
The linked posts are dealing with stopping a token from progressing. The token is just giving out a task and waiting until it has finished in this case. You need to stop the object that is executing the delay task.
