Throughput rate per arbitrary unit of time
matthewjouffray
matthewjouffray
[ FlexSim 23.2.2 ]
I have a process where the throughput is very slow and the template visualization of throughput per hour isn't useful. I am trying to get a table or visualization for throughput per week. Specifically I am trying to count the number of flow items with various label values per unit time. So "in week 1 we had x number of item with 'label1=a' label go through, and y number of items with label2='b' label, in week 2 etc..." The end result I want is a table that has a new row for every week, with a column for the count of every label value I am interested in.
What I have tried so far: I made a statistics collector which listens to processors at different stages of the process (the ones I am interested in), and they record the labels and model.time for every flow item on exit. That works fine.
When I try to use a calculated table however, I cannot seem to find the right options to aggregate the data such that I get a count of flow items with the right labels over a one-week period. I've tried using pure SQL but FlexSim seems to have a limited number of functions available and doesn't support FLOOR or timestamp functions. I know this is possible, any ideas?
moehlmann_fe
Here's an example of how this could be done. I use a Statistics Collector with a column. If the label name/label value pair of an item matches, the respective column is incremented by 1, otherwise it keeps its previous value.
specific-label-throughput.fsm
matthewjouffray
Awesome, thanks!
