I have a few questions about template inheritance in FlexSim 2021 Update 2:
If you create a template object, can it be put into the user library?
If so, if you edit the properties of the library object are they automatically inherited by the instances in the model?
Can the parent object itself be a child of another object such that some of the inheritance cascades from the grandparent... all whilst in the library?
If not, what do you envisage will be the methodology (e.g. having a set of templates in the model which are not attached and represent an internal “template library” within the model).
