TE save and return to home location via process flow
LCACoreSdnBhd
LCACoreSdnBhd
[ FlexSim 23.2.1 ]
Hi, I have a model where my TE will return to home when it has no tasks (did not manage to pull from TE work global list). I referred to the Kiva model to save to the home location and return to the location but I noticed that my TEt travels to a position off center from the default position. Appreciate your help to look into this.find slot by matching label and travel to home when idle v3.1.fsm
https://youtu.be/3AQ-cjOS9tY?t=2683
jason_lightfoot_adsk
You have exceptions at reset - please remove and re-add the task executers from/to the TE process flow.
Have you tried unchecking the relative check box to use the absolute coordinates?
LCACoreSdnBhd
@Jason Lightfoot I have tried but I may not fully understand your instructions, recording as attached below.
https://www.loom.com/share/4a8607d168784fe5a7fe3c6f1095acfd?sid=c907ba75-8069-4a3e-802e-5b18efaffdf2
Is this related to this error:
exception: Exception caught in TreeNode::callMemberFunction() main function. Throwing... exception: FlexScript exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... at MAIN:/project/events/OnOpenModel/rebuild process flow block instances
It's the exception at reset (and possibly when opening the model).
Just look a the process flow instance members in the Properties panel on the right - you'll see the three task executers listed. Just remove them and then add them back.
