TaskExecuter::onFinishTask isn't executed when the task is preempted
amerloQ2XZU
amerloQ2XZU
[ FlexSim 22.0.1 ]
today I discovered that the trigger "OnFinishTask" isn't executed when the task is preempted. I believe that it isn't a software issue, but it is by design. Could someone explain the reason? I would suggest to execute "OnFinishTask" also when the task is preempted.
In my model I am logging all OnBeginTask and OnFinishTask and some record missing when the task is preempted.
I attached a very simple example to show the problem.
onfinishtask.fsm
jason_lightfoot_adsk
Alessio you can detect the preemption and resumption using a process flow (example attached). I think OnStartTask and OnFinishTask are doing what they're meant to - if you'd like to suggest adding OnPrempted and OnResumed then feel free to put a feature request here or sent to the dev email.
onfinishtask_jl2.fsm
amerloQ2XZU
Thanks jason for your support!
