Task Sequence Using Global Task List
john_an
Message 1 of 10
john_an
[ FlexSim 18.2.3 ]
operator-task-list.fsmGood Day,
I am trying to figure out how to get the operator to complete all the tasks on a plane before they move to the next plane. I attempted using a global list to no avail. If possible, wondering if I could do it with the regular 3D Logic. However, if it's easier to use process flow, then i'd appreciate a solution.
Thank you.
Replies (9)
Message 2 of 10
braydn_t
@John AN
This is a solution for Process Flow:
I would have 2 different event triggered sources for each plane. They will create a token when work enters the system, and assign a label with the plane number. Then you acquire the operator, using a query to select the right plane number (Order by plane ascending) and then complete the Process Flow Chunk.
Here is a simple example of this:
plane-example.fsm
Message 3 of 10
john_an
Braydn,
My bad. I used the plane just to differentiate between the two areas. Removing the planes, how would I ensure that the operator completes all the tasks in the first section, before moving down to start and finish the next one?
Message 4 of 10
braydn_t
@John AN
I understood that. You can change the variable plane to be whatever you want, but the concept is the same. The only difference to the model I sent would be preemption. If you want the operator to do all of the tasks in area 1, and then go work on tasks in area 2 until there are more tasks to complete in area 1, the model I sent you will work. If you want the operator to complete all the tasks in area 1, then go and complete all the tasks in area 2, then I can give you an example of how to do that.
Also, the example will work with a dynamic number of created items. If you want either situation but you will know the number of created items before hand, this will be much easier.
Message 5 of 10
john_an
@Braydn T Awesome, I'll work on using a different variable for the model. The second option is what i want (The operator to complete all the tasks in area 1, then go and complete all the tasks in area 2.)
Message 6 of 10
braydn_t
@John AN Do you know the number that will be arriving before hand, or do you want the items to arrive on statistical distributions?
Message 7 of 10
john_an
@Braydn T 1 item shows up onCreation.
Message 8 of 10
braydn_t
@John AN
Does that mean you know the number before hand?
Message 9 of 10
john_an
@Braydn T
Yes i do.
Message 10 of 10
braydn_t
@John AN
If you know the number that will arrive, you can do something like this:
example-2.fsm
