task sequence-load-unload
yoni_a
Message 1 of 8
yoni_a
[ FlexSim 18.1.1 ]
I have a once upstream processor connected to 2 downstream processor, two operators move the completed parts from the upstream processor to the downstream processors, and then they follow a task sequence in the downstream processors, how can I tell the upstream processor to use the task subflow-task sequence I created for each individual operator to move the items to independent stations, each operator work on his own in a separate station(processor)
Replies (7)
Message 2 of 8
joshua_s
Can you upload your model or at least your task sequence for us to have a reference?
Message 3 of 8
yoni_a
capture1.png see image @Joshua S, file is too big
Message 4 of 8
joshua_s
How are you obtaining the processor you are assigning work to? you can use the reference code:
current.centerObjects[1]
and replace current with the processor you have assigned work to. This references the operator connected to the processor.
Message 5 of 8
yoni_a
load-unload-task-sequence.fsm
see attached example, @Joshua S , items must be unloaded from welder by operators to two downstream masking stations, do the task sequence and move to the last station to clean the flow item
Message 6 of 8
joshua_s
Is this flow kind of what you are looking for?12164-load-unload-task-sequence-change.fsm
Message 7 of 8
joshua_s
@yoni A Did this work for you?
Message 8 of 8
yoni_a
yes it did @Joshua S
