Task Sequence List
Task Sequence List
neil841027TTD9C
Task Sequence List
neil841027TTD9C
[ FlexSim 23.2.0 ]
I have a question that if I can pull more than one task sequence from a task sequence list.
I have a task executer which capacity is 20.
Or is there any other way to dispatch the task sequence to one task executer with more than 1 capacity and the task sequence are ordered by priority?
Thank you for your answer!
joerg_vogel_HsH
There are many other ways. You can achieve it in 3D logic. You use a dispatcher object. A dispatcher stores Tasksequences like a list. It dispatch tasksequences to available taskexecuters. A taskexecuter can look for other tasksequences stored in dispatcher in Break To function, as long as the Taskexecuter has capacity left.
moehlmann_fe
Observer
Observer
As Jörg suggests, you can do this by adding a "Break" task to the task sequences and using a dispatcher to store them.
ts-priority-dispatcher.fsm
You can also keep the list and have the TE pull additional task sequences in the "Break To" field.
ts-priority-list.fsm
neil841027TTD9C
Thank you!! It works!
neil841027TTD9C
Thank you!
