Task Sequence Label
Task Sequence Label
yoni_a
Task Sequence Label
yoni_a
[ FlexSim 18.1.2 ]
what label should I establish for the token in this simple task sequence example, the operator load a part from queue1 unload it to processor 1, but it gives me error is "token.item" the right label to use
joshua_s
There's several referencing issues, take a look at this model for the correct referencing. Labels on the tokens need to have a reference to something in the model if you want to use them.
example.fsm
