Task Executor for output from separator
kshitijdhake
kshitijdhake
[ FlexSim 22.2.0 ]
I am trying to use operator only for the contents and not for containers. Sample 1.fsm
moehlmann_fe
You can use custom code in the Transport Reference field. If it's an item that is leaving through port 2, the operator is used. Otherwise the item is moved to the destination directly.
sample-1-fm.fsm
