Task Executor Flow Item Not Following Path
RTinkess31
RTinkess31
[ FlexSim 22.2.2 ]
I've got a source that is creating Task Executors as flow items and I've added a mandatory path from the source to a queue. However, the people are walking straight from the source to the queue and ignoring the path.
Is there something extra I have to do to get them to follow the path?
TE_AStar_ManadatoryPath.fsm
andrew_o2
Hi @RTinkess31, would you be able to post your model so we can take a look? It seems like you may not be adding your Task Executors to the navigator that would make them follow the path.
RTinkess31
Hi @Andrew O , I've attached a sample of what I'm trying to do. Basically I want the TEs to walk through the maze but they're just going around it.
LongG
As v23.0.1.fsm show ,it did the trick (Source's on creation tirgger).But is there anybody haver another way that is not 'contextdragconnection' ? I forget the command may make traveler's 'Use Mandatory Paths ' checked.
RTinkess31
Thanks, that code snippet will work for me.
