Task error
Task error
ioanna_c
Task error
ioanna_c
[ FlexSim 19.2.4 ]
i have a task error (1st photo) in my model, that i cant find where is the problem. This is my model test11.fsm
Also, i am looking for a way to made operator separate 6 orders in Orders_Queue1, after he has collected them in once. I've made an Order List ID (2 photo) but nothing again.
Does anyone know something about that?
jason_lightfootVL7B4
So if we answer here, should be not answer @Fwteini K's latest question ? It seems to me you consistently duplicate your questions while you're working together. Please stop this.
ioanna_c
i repeat that we have some same project but different data. If we worked together we would post 1 question the time. I'm reading your answers in @Fwteini K's questions and im trying to fix my model too.
Thank you
In understand but why should we create two models if they are doing the same thing - it should be one model into which you load different data.
ioanna_c
I'm sorry, my false. Νext time we will upload one model without bothering you. Αnswer where you deem necessary. Thank you again!
The Task Sequence Error:
I the model sPlanPickSequence_PickRun6orders.fsm - the travel task now causing this error had "Empty Pallets" as the destination - a pointer to an object. You've changed this to token.destination which you have not defined - so the picker doesn't know to where it should travel.
The Exception in the Order List Field: TokenID
This list is just used to get unique order numbers. The pushed values are order numbers. They do not have row and column attributes so can't be used to look up a table cell in the GlobalTable "Picking_List".
Decanting Boxes to Order Totes:
I've posted a model in the other question here.
