Task error - Task sequences
marc_r5
marc_r5
[ FlexSim 22.1.0 ]
Layout v3.1_3.fsmHello!
When creating a sequence of loading and unloading (with possible travel), I get this error.
Why is that?
Attached the model
moehlmann_fe
When I run your model I get a different error which is caused by your second process flow resource being a numeric resource and not referencing a task executer or group of task executers.
Also, you are not releasing the acquired crane. The resource is assigned to the "puenteinterior" label, but the Release activity is set to release a resource assigned to "token.resource".
The error message in your screenshot shows you that the load task is missing references to the item that should be loaded and the station where is should be loaded (Involved 1/2 are both NULL). In the second Load activity you are referencing "panelH" which does not exist on the token.
ryan_c10
Hi @Marc R5, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
