TASK 4.2 - AGVS USING PROCESS FLOW pickup point
oceanbluesky1993
oceanbluesky1993
[ FlexSim 23.2.0 ]
I followed Tutorial 4.2 to add pickup area in the model. However, item box got stuck at the processor. Hope I can get some advice, thanks! AGV Tutorial.fsm
moehlmann_fe
Observer
Observer
Was the model originally created in an older version? Because the AGV network has two connections types called "LookForWork" and "NextLookForWork" which should be called "WorkForwarding" and "NextWorkPoint" respectively in the version you are using.
This discrepancy causes an exception when the AGV template is added to model and tries to set certain node values.
Update those names, remove and re-add the AGV template and then the model should run correctly.
oceanbluesky1993
Yes, I created from the old version, I'll correct it based on your suggestion, appreciate it!
