Table sort
Table sort
tomi_kosunen
Table sort
tomi_kosunen
[ FlexSim 20.2.3 ]
Hi
I have Table that has ~88000 rows and 2 columns (both numeric). I have to sort the table by a column 1 (on model reset). The sort takes about one minute to make. Is there a way to make it any faster?
Used command: myTable.sort(1);
lars_jacobsen_ScandiSim
Have you tried to use Table.addIndex and Table.getRowByKey instead of sorting your table? It requires that it is a bundle table.
MBJEBZSRG
Hi Tomi,
As Lars said, addIndex() is perfect for that task, but remember that it only works on Bundle Data tables. An alternative is to use a query with a ORDER BY Column1 ASC/DESC, Column2 ASC/DESC. This is also pretty fast even on non indexed / non bundle tables.
I did a small test with a table with 88000 rows and two columns.
  • Using Table.Sort() took 158,76 seconds
  • Using a query and dumping the sorted result in another table took 0,77 seconds
  • Converting the table to bundled data and indexing both columns ordered and then using Table.Sort took 0.04 seconds.
  • Using a query on the bundled table took 0,35 seconds.
tomi_kosunen
Perfect. What would be the sql syntax, if the Column header has space in its name, like
"Sort Order"?
This doesn't work: string queryStrings = "SELECT * FROM OrdetTable ORDER BY 'Sort Order' ASC";
You need to use square brackets [] when you have names with spaces. "SELECT * FROM OrderTable ORDER BY [Sort Order] ASC"
https://docs.flexsim.com/en/21.0/Reference/DeveloperAdvancedUser/SQLQueries
Ben_WilsonADSK
Hi @tomi.kosunen, was martin.j's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
