Table name as token label
mariancretu_v
mariancretu_v
Hello all,
Is it possible to reference a table by a token label?
For example I have 4 global tables each one for a rack.
In PF I need to write in the table which corespond to each rack. For The racks I have a token.rack label which have values like rack1, rack2 etc.
How can I define a table like Table rack_to_write = Table("token.rack");
Thank you.
sebastian_hemmannE3JAU
In absence of a model I will try to write the code in here:
string TableName = token.rack;
Table rack_to_write = Table(TableName);
But this only works, if you really have a string in your label. If there is a pointer in there you maybe will have to change "token.rack" to "token.rack.as(Object).name" or something like this.
To make it easier I normaly use a Case in the Assign Label activity and set the Table pointer as a label value 😉
