Table.getValueByKey returns exception when no value can be found
MBJEBZSRG
MBJEBZSRG
[ FlexSim 20.0.1 ]
I am using the getValueByKey() to look up information in a bundle table, but there are situations where key I look up simply is not in the table, and that is ok - I can go on from there. Unfortunately the method throws an exception and quits the script or activity it is in with unpredictable behavior to follow.
exception: FlexScript exception: no row found for key 5 in col 1 at <no path> c: <no path> i: <no path>
Is there a way to catch this exception or have the method simply return NULL if no matching result is found?
philboboADSK
If you don't know whether the key is in the table, use table.getRowByKey() instead of table.getValueByKey():
Table table = Table("GlobalTable1");
int key = 5;
int valueCol = 2;
int row = table.getRowByKey(key);
if (row)
	return table[row][valueCol];
else
	return 0; // handle what to do if the key isn't in the table
//return table.getValueByKey(key, valueCol);
Phil BoBo
Sr. Manager, Software Development
