- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
1) Last few days, I keep getting System Console window pop out (refer to attached JPG files) when I open any existing and new models with Dashboard display. I was using Flexsim Version 17.0.1 then. It seems to happen after I try saving some Dashboards to HTML files.
2.After I upgrade to Flexsim Version 17.0.3, it still has the System console pop out (blank window) whenever I open any model files with Dashboard. If I close the System console and run the model, some of the Dashboard display cannot be seen. I need to reopen the System console, close it again and then the dashboard display can be seen.
3.Now whenever I add Dashboard when creating any new model, the System console always pop out with message “exception: could not write html file”.
You can refer to attached sample “tryout.fsm” model which I created to experiment with this issue.
Please help advise on this problem and how to fix this ? Thanks!
