System console createvent error.
kamil_ks
kamil_ks
[ FlexSim 19.0.4 ]
I have received a System Console message as below:
"createvent: event time is in past: event time changed to present. Object: Source eventtime: 1246777.000000, time: 1248179.000000 Zaladunek"
What may be the issue of this problem? Could anyone describe more this error message?
joerg_vogel_HsH
You set a negative creationtime. You use a statistical distribution that is able to return negative values. You can prevent this with a maximum function in combination of the statistical distribution.
Math.max(normal(55, 27), 0);
