Stuck and remotely placed objects in 21.2.2
frantisek_r
frantisek_r
[ FlexSim 21.2.2 ]
Please, once 21.2.2. installed (and several times re-installed), chosen objects are still placed far away from where they are placed + objects stuck and not able to pick/move/choose them at all. Previous 21.1.5 works pretty fine. Thanks in advance for debugging
1 View
Ben_WilsonADSK
It would be helpful to have some information about your system. Please post back a screenshot of the screen from Help > About FlexSim.
You may want to try some of the suggestions in the article Graphics Compatibility - Common Problems and Solutions - FlexSim Community.
frantisek_r
Hi, pls there's prnt scrn of system information.
Thanks very much in advance for any advice how to solve it out...)
Ben_WilsonADSK
@František R , What version of Parallels are you using?
philboboADSK
From your About screen, I can see that FlexSim received an OpenGL 2.1 context.
Did you have a setting somewhere that configured FlexSim 21.1.5 to be able to use OpenGL 3.3 hardware acceleration? Something that you need to also now specify for FlexSim 21.2, which is installed as a separate program?
You could also try selecting Core Profile (3.3) in Global Preferences > Graphics > OpenGL Context. Restart FlexSim after changing this setting:
That way, FlexSim will specifically ask for a 3.3 OpenGL Context instead of asking for the system's recommended context.
Phil BoBo
Sr. Manager, Software Development
frantisek_r
Perfect, it works setting OpenGL Context to 3.3 at preferences.
Thanks very much:)
