Stopping and Resuming stations on conveyor (>2 stations)
bobby_lutz
Observer Observer
bobby_lutz
Observer
Observer
[ FlexSim 22.1.0 ]
I am trying to build a conveyor line with 10 stations (varying process times). I want to stop objects from moving to the next station until the next station is empty.
I tried using logic from https://answers.flexsim.com/questions/53474/stopping-and-resuming-objects-using-conditions-in.html?c.... When I add a third station the objects move from station 1 to station 2 when 2 is complete with processing.
bobby_lutz
Observer
Observer
I converted the conveyor/stations to processors. I highly recommend this for basic assembly line sims.
kavika_faleumu
Hey @Bobby L, the logic you posted will only work for two stations because the Process Flow only watches for the state of the second station. I modified that model to use an Object Process Flow and attach several stations to it. An Object Process Flow allows you define logic once for a set of machines/processes that use the same logic.
I started by adding more Stations and then A-connecting them together so each one knew which one was ahead of it.
Most of the Process Flow logic was the same, but I had to change a few things. First was the "Decide" activity's conditional statement. Before it was checking if the station ahead was "idle", but there was a problem - when a station was finished processing, it automatically set the station's state to "idle". This meant that if a box was ready to move and the box ahead of it was also waiting to move but not processing, the previous box would move ahead anyway. I changed it so it would look at whether or not there was an "active item" at the next station.
For a similar reason, I had to change the logic for waiting till the next station was open. I simply changed it to be "On Continue".
Hope this helps.
Multiple Station Stops.fsm
andrew_o2
Hi @Bobby L, was Kavika F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
