Statistics Collector - Previous row data replaced with NULL Value
FrancisKwa
FrancisKwa
[ FlexSim 23.2.2 ]
Attached model replicated the Statistics Collector Tutorial 2.9 - OUTPUT BY HOUR BY TYPE logic.
However, the replicated statistics collector logic in this model replaced the previous hourly row data with NULL value
Appreciate guidance to resolve this behavior.
moehlmann_fe
Observer
Observer
You put the fields of the "Output" column in the wrong order. In your model, when the "Finish" event fires, the column value is updated to None, rather than the current output.
You also need to uncheck the option to keep labels for finished rows. Otherwise the stored values will be cumulative rather than per hour.
FrancisKwa
Thanks for the guidance.
