State graph colors always revert to default after changing them
patrickABAWF
patrickABAWF
[ FlexSim 21.2.4 ]
In a dashboard, whenever I change the color of a state in the State graph properties, the color always reverts back to default when I hit Reset.
It does this whether Edit Mode is checked or not.
How can I make my color choices "stay" ?
philboboADSK
Please attach a model demonstrating the issue.
Phil BoBo
Sr. Manager, Software Development
philboboADSK
Is your complaint that the alpha component of the color is changing when you hit reset?
If so, then uncheck the "Adjust colors based on State Table" box:
On reset, the order of the colors and their alpha values are adjusted based on the State Table's settings if that box is checked.
See State Options (flexsim.com)
Phil BoBo
