Start recipes in machines
luis_rodrigues
Message 1 of 9
luis_rodrigues
[ FlexSim 24.1.0 ]
Hi. I'm working on a model in which each machine produces a list of recipes, that are represented in the "source" in the process flow. Right now I have arrival times for each recipe but I want to take off this times and make it, for example, if the first recipe ends the machine should start the next one and so on. Can anyone help me with this?
Also the model is returning an error in the "materialtype" global table that represents the quantity of boxes from each material a specific queue can hold.
Thank you in advance 🙂
mlall-NOVA.fsm
Replies (8)
Message 2 of 9
joerg_vogel_HsH
attached an example in standard 3d logic.
container items are created with type values in round robin style. Update components list values take into account an additional involved container item. Combiner is working in batch mode.
UpdateComponentList_round_robin_container_item_batch_mode.fsm
Message 3 of 9
luis_rodrigues
Thank you for your answer @Joerg Vogel. But I don't see how that example can help me with my problem since I'm working with process flow and not with standard 3d logic.
Anyhow, @Felix Möhlmann helped me before with this model, I hope I can reach him for help.
Message 4 of 9
moehlmann_fe
Observer
Observer
You already have logic in place that only lets two tokens per combiner through at a time (one active and one to acquire for the next order). I don't see a problem with simply setting all creation times to 0. (The model might run a bit slower because the zone has to loop over more tokens to determine how can enter next).
And the headers in the table Recipe05 are wrong, which causes the error.
Message 5 of 9
joerg_vogel_HsH
@luis_rodrigues, I enhanced my uploaded model by a process flow example.
Message 6 of 9
luis_rodrigues
Thank you @Felix Möhlmann that was a great help and it worked perfectly.
Right now the machines follow the list of recipes and stop when all the recipes are finished, but I want to ask If it's possible that they loop the recipes (for example, when ML00 finishes the 10th recipe it goes to the 1st and so on)
Message 7 of 9
moehlmann_fe
Observer
Observer
Creating 1 token for each recipe that is supposed to be in the rotation and then looping it back to the start (resetting any labels where that is necessary) instead of sending it to a sink should work.
Message 8 of 9
luis_rodrigues
Can you please check if this is correct?
I used an old version of the model as reference.
mlall-NOVA.fsm
Message 9 of 9
moehlmann_fe
Observer
Observer
Looks correct.
