StaffNotWalking?
StaffNotWalking?
rajankur6494
StaffNotWalking?
rajankur6494
[ FlexSim HC (other) ]
Hi Team,
I am using clerk 3D object as staff in model. I have changed the idle animation to UseTablet from quick properties. The problem is staff is not walking after serving 1st patient. Staff is only sliding.
Is it bug or do I need to change something?
Also how can I show tablet in animation?
StaffNotWalking.fsm
Healthcare Version 21.1.5
Thank you!
Matthew_Gillespie
This is a bug. When the staff leaves the chair its starting its Stand animation, but it should look up the currently defined Idle animation and start that instead. We'll get this fixed for the next bug fix release.
A workaround you could use is to start the Walk animation on the staff before releasing them. This will stop the Stand animation from being started.
staffnotwalking_1.fsm
Please ask the tablet question as its own question.
Matthew Gillespie
FlexSim Software Developer
rajankur6494
Thank you! @Matthew Gillespie
