Stack Pallets with Loads - Pallet Packing Method
amit_k2
amit_k2
[ FlexSim 21.1.4 ]
I want to stack tow pallets with single load on each pallet like shown in the picture below
1624372869625.pngStack Pallets
However, it seems that if I use a dummy pallets to pack, it makes them stack like this
1624372972390.pngUsing dummy pallets
I am using "Simple" packing method on the dummy pallet.
I am using a dummy pallet because this stacked load gets separated downstream using a separator.
What is it that I am missing? Probably adjust the spatial offsets?
Pallet_Stacking.fsm
eric_m3
Hi @Amit Kulkarni, you should be able to get away with not using the dummy pallets. I just added 2 connections from the conveyor to the combiner and changed the combiner packing list to be 1. Then I updated the "pallet" flowitem pack contents to be simple. They stack and separate just fine now.
pallet-stacking (1).fsm
amit_k2
Thank you! I had completely forgotten that we can have two connectors to a combiner from the same object!
