SQL query to get the average value of a field
patrickABAWF
patrickABAWF
[ FlexSim 21.2.4 ]
I've been trying for hours to write a very simple SQL query but I can't seem to find the correct synthax.
I have a List called "FinishedGoods" and I want to get the average of the field "Leadtime" and return it as a double avglt.
I wrote this but it doesn't work. I get "syntax error, unexpected '[', expecting end of code" in the Compiler Console.
Table result = Table.query("SELECT Leadtime FROM FinishedGoods \
AVG[Leadtime]");
double avglt = result[1]["Leadtime"];
What's wrong? I can't see it.
Thanks a lot,
Matthew_Gillespie
You need to put the AVG() function in the SELECT statement and use parentheses, not brackets:
SELECT AVG(Leadtime) FROM FinishedGoods
You can then return the result with result[1][1]
Table result = Table.query("SELECT AVG(Leadtime) FROM FinishedGoods");
return result[1][1];
You can also rename that column with an AS statement
Table result = Table.query("SELECT AVG(Leadtime) AS Leadtime FROM FinishedGoods");
return result[1]["Leadtime"];
Matthew Gillespie
FlexSim Software Developer
patrickABAWF
Thanks this works. Also, if I want to get 3 things from the data, can I do them in the same query or do I have to do 3 queries as I did below which works fine?
Could I do it more elegantly by doing the 3 queries within the first one:
AvgLeadTime = result[1][1];
Table result2 = Table.query("SELECT MIN(Leadtime) FROM FinishedGoods");
MinLeadTime = result2[1][1];
Table result3 = Table.query("SELECT MAX(Leadtime) FROM FinishedGoods");
MaxLeadTime = result3[1][1];
patrickABAWF
Forget my comment. I found the more elegant way:
Table result = Table.query("SELECT AVG(Leadtime), MIN(Leadtime), MAX(Leadtime) FROM FinishedGoods");
MinLeadTime = result[1][2];
MaxLeadTime = result[1][3];
I'm starting to get the hang of this SQL thing and loving it !!!
Thanks Matthew !
