SQL Header Group by Query
apallaroEJJ5N
apallaroEJJ5N
Community Visitor
Community Visitor
[ FlexSim 24.1.0 ]
I am making a query to get the best item type product based on certain conditions that must match. The problem is that I am not able to get the row headers with the item type that I am grouping by.
Is there a way to do this?
SQL Group By Example Headers.fsm
Here is the model.
In this example I want the final answer to be "30"
moehlmann_fe
The result of the query is an internal data structure and doesn't have row headers, as far as I know. You will have to add the ModType column to the SELECT clause and treat it as its own column.
apallaroEJJ5N
Community Visitor
Community Visitor
You are right, that worked. Thanks
Table TableLineModules = Table.query("SELECT [ModType], SUM(CASE WHEN ([Zone] = 3 OR [Zone] = 4) then 1 else 0 END) as [Zone3&4], \
SUM(CASE WHEN ([Zone] = 5 OR [Zone] = 7) then 1 else 0 END) as [Zone5&7], \
COUNT(*) as [Total] \
FROM [Data] \
GROUP BY [ModType] \
ORDER BY [ModType] ASC ");
TableLineModules.cloneTo(Table("TableQuery1"));
