SQL date/time import issue
sunil_b2
sunil_b2
[ FlexSim 21.1.5 ]
When importing date/time data into global table from sql db , the data/time fraction is off by 420 years in fractions . Below picture shows the date, its value in excel and imported value via DB connection
see the attach model with copy paste and import. into global tables
ryan_c10
Hello @Sunil B2,
It actually turns out that your SQL imported value corresponds to 420 years, 228 days, 8 hours, 29 minutes, and 50.237 seconds. This is the amount of time that has elapsed since January 1, 1601 12:00:00 AM, which is the earliest time/date currently allowed by FlexSim. My guess would be that FlexSim produces the time/date format by adding the EventTime in seconds to that initial value or something along those lines.
Does this address your question?
sunil_b2
Ryan
No. Why did DB import offset by 420 years is the issue?
ryan_c10
I'm sorry for the misunderstanding. The difference between the Excel value and the SQL DB imported value is what date/time they are treating as zero and the units they are using to measure time.
Excel is using 12/30/1899 0:00:00 as its "zero-time" and is measuring the time since then in days.
FlexSim (and apparently the SQL DB, at least when imported) uses 1/1/1601 0:00:00 as its "zero-time" and measures the time since then in seconds.
I hope this helps!
ryan_c10
I'm attaching a model that just has a couple scripts in it. One of them converts a time into a date/time from Excel format, and the other in FlexSim format. But, they both output the same date.
Hope this helps!
SQL DateTime Convert.fsm
Jeanette_Fullmer
Hi @sunil.b2, was Ryan Clark's answer helpful? If so, please click the red "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
sunil_b2
It seems to be a bug in Flexsim .. When I import into excel from MSSQL the date/time come correctly without any offset.
