Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Split item based on label and send to specific port
eric_r6
eric_r6
[ FlexSim 20.2.1 ]
Test File 2.fsmHello,
I am trying to get my separator to split the incoming items into 3 different items. In the attached model I have two different items arriving at Separator1 based on an Arrival Sequence. If the item that shows up is SKU1, I want it split into 3 different items. Ideally these would be labeled wld1, wld2, and wld3. Wld1 and wld2 would then go to Queue1, and wld3 would go to Queue2.
If SKU2 shows up, I want it split into 3 different items. Ideally these would be labeled wld4, wld5, and wld6. Wld4 would go into Queue1, and wld5 and wld6 would go into Queue2.
My thoughts were to set this up using a process flow that runs a subflow depending on what SKU# arrives at the Separator. In my full model I will have about a dozen different SKUs that will get split and go to different Queues. Below is a visual of what I am trying to do.
Thank you
joerg_vogel_HsH
If you do this with process flow, then you use a simple processor or process flow processor object. If you do this in 3D object logic and exit trigger in a separator object, you might think about to label the items as wld’s after you decided where they go simple by counting. I mean you send them to the queues and then you set the label On exit.
parker_s
@Eric R6
Here is a model that does what you want to achieve:
support_test-file-2.fsm
You were on the right track, it would be best to do this with process flow. The subflow I included assigns the WLD labels and moves the items to the wanted destination. I have 2 additional global tables that contain values for the WLD labels and the destinations (the "WLDassignments" looks like it could be combined with your "Table1").
I believe this could be modified for your application of more SKUs and queues, except if some SKUs need to be split into a different quantity than 3. In that case we may need to completely remove the 3D separator and handle the split logic in process flow.
I hope this helps!
eric_r6
@Parker S,
This does work really well for SKUs needing the same number of splits. In my expanded model I will have 12 total SKUs. Depending on the SKU they could be split between 3 and 7 different ways. Below is what my expanded model will include. I don't have to have the 3D separator in the model. With this many SKUs and splits would going fully to process flow be the way to go?
One work around that I found was to split everything 7 ways, and then change the destination to a sink if they weren't all needed. For example, if SKU1 was split in WLD1 through WLD7, and I only needed up to WLD3 that WLD4 through WLD7 would end up going into a sink.
Thank you,
Eric
parker_s
@Eric R6
I thought we may have to do everything in process flow, but this way works fine:
support_test-file-3.fsm
I have added a label on the Source arrivals named "SplitQuantity" and use that for the split quantity on the separator
and for the request and require numbers on the Pull from List activity
token.Items is assigned in the event-triggered source.
eric_r6
Hello @Parker S,
That is working properly. Thank you for the help on this one!
