Split existing batch
alexander_muff
alexander_muff
[ FlexSim 17.0.0 ]
batching-test-model-rev0.fsmSome of my processes are processed in batches, while others are processed individually. How do you split/break an existing batch?
I have a sample model that does it with a create tokens block. Is there a simpler/cleaner way to do this?
jeff_nordgren
@Alexander Muff
Attached is your model with the addition that I made. I added the part to the right of your Process Flow. I believe that it is doing the same thing that yours is doing. Take a look at the model and see if this is what you were looking for.
If you have any problems or questions, please let us know.
Thanks.
batching-test-model-rev0-jn1.fsm
alexander_muff
When I open your model there is no Process Flow.
When I try to add a Process Flow, I get errors:
exception: FlexScript exception: MAIN:/project/exec/globals/nodefunctions/assertmoduledependency exception: FlexScript exception: VIEW:/nodefunctions/processflow/addprocessflow
