Source Random Arrivals
kevin.megee
kevin.megee
FlexSim Community,
I'm trying to create a simulation where I have 5 "Bands", Band 1,2,3,4 and 5.  Each Band has a different quantity and process time (PT) assigned to it using labels.  I have the processor's run time set to match the PT label.
I'm stuck trying to get the source to randomly choose to create each Band from either the arrival table or global table and set each Band to a color so that it's easy to track throughout the model visually.
My main model is run using triggers and code snippets.  Any suggestions will be greatly appreciated!
joerg_vogel_HsH
Start simple and primitive. If you cannot do it in a single object or process flow activity, then use more.
If you cannot get all conditions fulfilled at once, then you use additional process flow activities.
Create a process flow token with a distinct important attribute then use a create object or create token activity to get more of same kind.
A batch activity can easily duplicate tokens: collect one token let more tokens exit.
